DCO - 8.2.12 - use Insight to create server inlet temp report
  • EcoStruxure IT forum
  • DCO - 8.2.12 - use Insight to create server inlet temp report
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 04:21 PM . Last Modified: ‎2024-04-03 05:08 AM
1162
I have customer running DCO 8.2.12, they have ITO and Insight and are monitoring servers via ITO using IPMI.  ITO is able to get the server inlet temperature, is this data stored in the DCO database anywhere or is still only live data?  If it is stored in the DCO database, is possible to create a custom report for historical server inlet temp using Insight?
(CID:138807228)
  • Data Center Operation
  • IT Optimize
1162
Hi Andrew,
The Server Inlet temperature, it's a live data and not recorded in DCO database.
Kind regards
(CID:138809340)
Replies 6
anyone?
(CID:138808376)
1163
Hi Andrew,
Kind regards
(CID:138809340)
Thanks Jef, I kind of assumed that based on another answer I saw.  Are there plans to address this in a future release or through another protocol like Redfish?
(CID:138809566)
Posted: ‎2020-07-05 04:21 PM . Last Modified: ‎2024-04-03 05:07 AM
Hello Andrew
Redfish does collect sensor data from the server motherboards which means when more reporting features come to ITE it would be possible to report against server inlet temp as well as any of the other collected sensors.
Regards
Greg Sterling
(CID:138809590)
Great, thanks Greg.
(CID:138809596)
Posted: ‎2020-07-05 04:22 PM . Last Modified: ‎2023-10-22 01:32 AM
