Posted: 2020-07-05 08:37 PM . Last Modified: 2024-04-03 01:09 AM
Back in December 2018 I had a problem: (as a new portal ?feature? the old threads are closed, so I cannot add any comment)
Is there any investigation which results duplicate entries from virtual machine thru VMware integration? It basically kills the usage of this feauture.
Has been resolved in the latest DCO version?
(CID:147194504)
Hi Mate,
I have checked, that's an open case at the moment. I can let you know when the status of the case changes, thanks.
Kind regards
(CID:147194852)
Posted: 2020-07-05 08:37 PM . Last Modified: 2023-10-22 01:32 AM
