Posted: 2020-07-04 03:29 AM . Last Modified: 2024-04-05 03:18 AM
We have received the following message from DCO 8.1
Can anyone suggest what does this recommendation means? The solution was upgraded from DCO 7.x to 8.1
Thanks and regards,
TJ
(CID:128059500)
Hi TJ,
Have a look on your breaker mapping in your PDU or power panel, especially between measured sensor and breaker number.
Chris
(CID:128059809)
Hi TJ,
Chris
(CID:128059809)
Thanks Chris! Will double check the configuration.
(CID:128059829)
Posted: 2020-07-04 03:29 AM . Last Modified: 2023-10-22 01:31 AM
