DCO 8.02. Menu "External System Configuration" does nothing.
  • DCO 8.02. Menu "External System Configuration" does nothing.
129
72
Posted: ‎2020-07-03 08:34 AM . Last Modified: ‎2024-04-08 03:49 AM
1206
I go to "System Setup->External system Setup". Nothing happens; no window, nothing!
Also there use to be a menu to manage users in DCO. It is gone.
(CID:110006576)
  • Data Center Operation
Replies 8
1206
Since the DCO 8.0 release user management has moved to the web client:
Managing DCO users and user rights
(CID:110006580)
Thanks. That answers the second item.
(CID:110006627)
I'd like to add to Christian's answer that if you're used to working with previous versions of DCO, you'll notice some changes immediately in versions 8.x.
In DCO version 8.0 some features were moved from the desktop client into the new web client interface. In addition to user management as Christian points out, this also includes: license management, remote user authentication, and dashboards.
Other significant changes to existing functionality include changes to the way search works, and a complete redesign of the power capacity calculations.
You can find an overview of the changes here with links to the specific topics: What is new in StruxureWare Data Center Operation 8.0.
(CID:110006619)
Hi Denys, concerning "External System Configuration" menu: Can I ask for your client "application.log" file, to figure out what might be the issue - it is usually located: (Win.), C:\Users\\.isxo\8.0.2-xxxx\application.log (MAC), "user" > .isxo > 8.0.2-xxx > application.log (note: .isxo is a hidden folder) Kind regards
(CID:110006657)
There you go. Thanks.
application.log
(CID:110006687)
Hi Denys, Thanks, it seems the next step is studding the server logs and possibly a latest backup file. I will send you an invite to my =S= box shortly, just in case if you would kindly share your data with me, thanks. Kind regards
(CID:110006692)
Hi Denys, I was wondering if I should re-send my =S= box invite, or perhaps the issue with empty config menu is resolved? Kind regards
(CID:110007054)
Posted: ‎2020-07-03 08:35 AM . Last Modified: ‎2023-10-22 01:31 AM
