DCO 8.0 webmin interface access error
  • DCO 8.0 webmin interface access error
126
65
Posted: ‎2020-07-03 06:43 AM . Last Modified: ‎2024-04-08 10:42 PM
896
Hi Fellows,
I've  installed DCO 8.0 on a virtual environment, and I can access the server now via the desktop client and via webpage but I can't access the webmin, and everytime I try to log into the webmin  I receive the attached error message, anyone can help regarding this issue ?
BR,
Sameeh
(CID:108827733)
  • Data Center Operation
Replies 6
896
Hi Sameeh, Which browser (and version) are you using? It seems a browser related problem/prevention, try another browser such as Chrome. Kind regards
(CID:108828154)
I've used chrome ver. 45 and ie ver. 11 but i've the same, I should access webmin by user:root and the passowrd that I've created for root during starting is that right ?
(CID:108828160)
Posted: ‎2020-07-03 06:44 AM . Last Modified: ‎2024-04-08 10:42 PM
Hi Sameeh, The "root" login is disabled (by design), you should use the login name that you have created during the initial install/setup (it should be something different than root). Kind regards
(CID:108828161)
Hi Jef, thanks for you response, acually I've used the account that I have created during setup and finally I tried to login by root account, actually the username that I created was apc but the password was differnet so what I am gonna do to reinstall the dco server again then create a username and password don't contain apc because it seems it is causes problems. Thanks again 🙂
(CID:108828162)
Hi Sameeh, You are welcome - you might know it already, but just in case, please also notice that the web/desk top client login credentials can be different from webmin/ssh login credentials. By the way, I would suggest installing the latest release (currently 8.0.1). Kind regards
(CID:108828163)
Posted: ‎2020-07-03 06:44 AM . Last Modified: ‎2023-10-22 01:31 AM
