Posted: 2020-07-03 05:54 AM . Last Modified: 2024-04-08 11:11 PM
Is there anyway to resize text in DCO web client so a name of a device appears fully on it? Currently the maximum seems to be 9 on the device
And 15 on theinformation on the right hand side of the screen and 16 on the properties tab.
If you have write access you can click on the edit button to view the full name but if you only have read-only there seems to be no way to view the whole name of the device
(CID:108824785)
Hi James, I'm currently looking into this and will get back to you asap, thanks. Kind regards
(CID:108824795)
Posted: 2020-07-03 05:55 AM . Last Modified: 2024-04-08 11:11 PM
Hi James,
I was trying to see if this could be done with customizing web branding, but after a discussion with one of the main developers the best recommendation is a feature request. So I will go head and register it for you (hope it's okay with you), thanks.
Kind regards
(CID:108824888)
Hi James, This is to share a short update with community, that I have also registered an enhancement case (bug report) that a web client user should be able to read the device name - in summary we have both a bug report and a feature request: Feature Request: a way to resize text in DCO web client bug report: device Name field is too small in web client Thank you. Kind regards
(CID:108825055)
Posted: 2020-07-03 05:55 AM . Last Modified: 2023-10-31 10:47 PM
