Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
DCO 8.0.1 unable to mount NFS share
  • EcoStruxure IT forum
  • DCO 8.0.1 unable to mount NFS share
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 07:06 AM . Last Modified: ‎2024-04-08 04:18 AM
1170
In webadmin I selected to mount NFS share at menu "Filesystems". When fill up necessery data and click on Create I receive the following error:
Failed to save mount : NFS Error - mount: wrong fs type, bad option, bad superblock on :/vol/,missing codepage or helper program, or other error (for several filesystems (e.g. nfs, cifs) you might need a /sbin/mount. helper program) In some cases useful info is found in syslog - try dmesg | tail or so.
Is it possible that mount.nfs is not installed on the CentOS?
(CID:108828730)
  • Data Center Operation
Replies 12
1170
Dear Mate,
I have used Common Internet Filesystem Mount under File System to mount my backup in DCO 8.0.1. It has worked.
I hope this helps.
Bala
(CID:108828785)
Posted: ‎2020-07-03 07:07 AM . Last Modified: ‎2024-04-08 04:18 AM
Hi Bala,
Thanks for your help but I have to use NFS share and CIFS. I have a common NFS storage space to DCE and DCO therefore do not want to create a new one only to DCO.
Mate
(CID:109446899)
Posted: ‎2020-07-03 07:07 AM . Last Modified: ‎2024-04-08 04:17 AM
Sorry, Me either unable to mount NFS on DCO 8.0.1. I let the other community experts to suggest on the same.
(CID:109446900)
I applied the following solution:
Enabled http proxy and DCO 8.0.1 went to internet and installed nfs-utils.x86_64 package from official CentOS repo. It has 14 dependencies. After package install nfs mount went smoothly without any issue.
(CID:108829125)
We finally solved it by command: yum -y install nfs-utils
I just have to ask if it´s Schneiders intention that we need to be Linux experts to upgrade StruxureWare Operations in the future???  When such a basic service as starting NFS is not included in the upgrade I fear what´s coming in future versions...
/Peter
(CID:109447017)
Hi Mate,
I had captured this ( issue mounting a network file system (nfs) ) as an enhancement case, it is expected to be fixed in the next version, thanks.
Kind regards
(CID:109447410)
Does any know that new DCO 8.2 will fix this issue above yet?
(CID:126879610)
Hi Thai,
It should have been fixed since 8.0.2, thanks.
Kind regards
(CID:126879885)
Good Morning,
I'm having DCO 8.1.0 and I got same error above. Do you know what's else may need to be fix this error?
(CID:126880127)
1170
I am still experiencing this issue on 8.2.1-74019-fe3abe. Has this been resolved on 8.2.2 or do I need to perform the steps suggested by Mate Fekete?
(CID:128068519)
Posted: ‎2020-07-03 07:08 AM . Last Modified: ‎2024-04-08 04:17 AM
Hi All,
Just an update: It is still not resolved in version 8.2.2. I had to manually install nfsutils package with yum.
Mate
(CID:128748003)
Posted: ‎2020-07-03 07:08 AM . Last Modified: ‎2023-10-22 01:30 AM
