DCO 7.5 conversion single node to cluster
  • DCO 7.5 conversion single node to cluster
129
72
Posted: ‎2020-07-02 02:20 PM . Last Modified: ‎2024-04-09 04:14 AM
670
Hi All,
This is just a quick check to make sure I action this correctly.
I will need to shortly convert a DCO 7.5 single-node installation to a cluster.
Understand this should be as straightforward(!) as:
1 - Install cluster / high availability license
2 - Full DCO backup
3 - Rebuild DCO server hardware into a cluster configuration
4 - Restore DCO backup to cluster environment
Is this right, anything else I need to be aware of before proceeding?
David
(CID:99157410)
  • Data Center Operation
671
Hi David,
You are right in your procedure description 😀
That is the recommended way of doing it.
/Søren
(CID:99157448)
672
Hi David,
/Søren
(CID:99157448)
Thanks Soren
(CID:99157513)
Posted: ‎2020-07-02 02:20 PM . Last Modified: ‎2023-10-31 10:47 PM
