Posted: 2020-07-02 01:00 PM . Last Modified: 2024-04-09 11:38 PM
Upgraded 7.4.5 to 7.5
I had already created an Export External Config. I was trying to create an Import config but the OK button would not let me complete the process. I then tried to delete the existing Export config but again the OK button is absent. Attached Word doc has screen shots Trying to create DCO Import.docx
(CID:97485057)
Posted: 2020-07-02 01:01 PM . Last Modified: 2024-04-09 11:38 PM
The "Save and close" button is not available in the offline demo.
If this is not the offline demo try to uninstall the client. After uninstalling make sure the folder "C:\Program Files\StruxureWare Data Center Operation
Then download and reinstall it from the server.
(CID:97485164)
Hi Ed, we will have a look, thanks for sharing!
(CID:97485129)
That was with a 7.4.5 upgrade to 7.5. I loaded up a new 7.5 from ISO and I'm seeing the same behaviour. The OK button is missing
(CID:97485142)
(CID:97485164)
Thank you Kreston
That was a slip on my part
Cheers
Ed
(CID:97485362)
Posted: 2020-07-02 01:01 PM . Last Modified: 2023-10-31 10:46 PM
