DCO 7.4.5 lost webmin details
  • DCO 7.4.5 lost webmin details
127
65
Posted: ‎2020-07-02 10:43 PM . Last Modified: ‎2024-04-09 01:21 AM
675
Is there a process to recover / reset webmin username and password as we have a client that has lost these
TIA
Mike
(CID:105461213)
  • Data Center Operation
Replies 4
675
Hi Mike,
Here is the instructions to reset the user password on the DCO server (same user credentials to webmin):
Resetting user password on the server
Kind regards
(CID:105461217)
Jef, Do we have a way to recover the Webmin username as well as the password? I have a customer who does not know either, so we can not use the procedure linked above since it requires that we already know the user name.
(CID:108234934)
Hi Justen, It should easy to find out the user name (it should be listed in the /etc/passwd file, you can use cat or less to read the file). After rebooting the server in "recovery mode", then type for example: less /etc/passwd (type q to quite the file reading) Kind regards
(CID:108234979)
Posted: ‎2020-07-02 10:43 PM . Last Modified: ‎2023-10-31 10:46 PM
