Posted: 2020-07-02 10:58 AM . Last Modified: 2024-04-10 12:42 AM
I have a need to store dates in DCO and to search and report on these. There is no "date" CP type in DCO. Is this coming?
I thought of storing as a CP "Number" type like YYYYMMDD. Is there a better way?
If a 'data' CP is coming, when and how can we migrate from the above format to the new date type?
(CID:94601888)
Currently, new custom property types are not planned.
An idea would be, as you suggest yourself, to use the standard format YYYYMMDD (or YYYY-MM-DD) but stored as text. Using the integer or number types would result in unwanted formatting as seen in the screenshot below.
(CID:94601891)
Hi Ed, In addition to Martin's answer, you have another way of Tagging the device with Dates & you may draw inventory reports based on the Tags under the Reporting tool. In case if you are referring to the Installation dates, you still have a Generic property for that, under 'General Properties' for any asset, where you can define the Installation date & then getting the list view exported by sorting the 'Installation Date' column. Hope this helps.
(CID:94601977)
Posted: 2020-07-02 10:58 AM . Last Modified: 2023-10-31 10:46 PM
