DCO 7.3.6 LAB Navigation Tree Bug
  • EcoStruxure IT forum
  • DCO 7.3.6 LAB Navigation Tree Bug
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 09:27 AM . Last Modified: ‎2024-04-10 01:13 AM
968
Can anyone tell me if there somewhere to log bugs found within DCO software?
We are using 7.3.6
When using LAB if you delete a floor plan or a location containing a floor plan, the next time you open that LAB file the entire navigation tree is missing, leaving only the name of the deleted floor plan next to the globe icon. All the rooms are still there as you can still access them through the equipment browser or power dependency tabs by selecting an item and showing it in the layout, the room then opens.
(CID:93193306)
  • Data Center Operation
Posted: ‎2020-07-02 09:28 AM . Last Modified: ‎2024-04-10 01:12 AM
968
Hi Richard,
it is with great pleasure I can inform you that we have located the issue and made a fix.
The fix will be available in the next DCO release. I cannot give any dates but it will be available in the near future.
/Søren
(CID:93194173)
Replies 8
Hi Richard, You are welcome to log bug in here. We will make sure that bugs are reported to the correct development team. I have tried to reproduce the problem. But so far without success. If I delete a floor plan the rest of the rooms remain in the solution when I reopen LAB. If I delete a floor plan with rooms under the floor plan will those rooms also be deleted. Those rooms should be moved before deleting the top floor plan in case I wanted to keep the rooms. Can you maybe describe in a little more detail what you did ? Maybe also a screenshot of the hierarchy. Thanks in advance Jesper Bjerregård
(CID:93193308)
Hi Richard, Are you still experiencing the issue? As Jesper mention above we need a little more information in order to get to bottom of this. Let me know how we the best can help you on this matter? Maybe a screen sharing session in order to learn what is wrong at your end?
(CID:93193645)
Hi Jesper & Soren, yes still an issue for me. I have raised it already with Schneider just wanting to know if others had the same issue. Might be time for a clean install of our server. Richard
(CID:93193870)
Posted: ‎2020-07-02 09:28 AM . Last Modified: ‎2024-04-10 01:13 AM
968
Hi Richard,
I have finally found a way to reproduce your problem. That means investigation will be much easier going forward.
I will let you know of the results.
(CID:93193895)
Hi Soren, glad you can replicate the issue, that means I'm not going mad lol. Richard
(CID:93193908)
969
Hi Richard,
/Søren
(CID:93194173)
Thanks for the Update Soren, Great to see the prompt action taken to rectify the bug and have it rolled out in the next DCO release. Good to see the community working so well. Richard
(CID:93194193)
Posted: ‎2020-07-02 09:28 AM . Last Modified: ‎2023-10-31 10:46 PM
