Posted: 2020-07-03 04:36 AM . Last Modified: 2024-04-08 11:36 PM
Have anyone tried DCE using gmail smtp to send email alert? I am keep getting the below error although the login username and password is correct.
I have enabled account access for less secure app from the following search, but yet unable to send.
https://support.google.com/accounts/answer/6010255
Test environment:
Home network - no firewall etc
DNS set to google public DNS, no issue for DCE to ping smtp.gmail.com
DCE 7.2.5
smtp.gmail.com port 587 enabled secure SMTP in DCE
** have disabled 2-Step Verification, and other steps in the link but shows no luck.. anything I have missed?
https://support.google.com/mail/answer/78754?rd=1
Law
(CID:106891167)
Found the root cause. Need to ensure which google account you have signed in when enabling "less secured app" in the below page
https://www.google.com/settings/security/lesssecureapps
no issue with port 587
(CID:106891181)
Have you tried using port 25 instead? I usually have better luck with port 25, SSL enabled.
(CID:106891170)
thanks for the suggestion, I have found the issue, tried port 25 but no luck.
(CID:106891182)
(CID:106891181)
Sent you screenshots to your email..
(CID:106891184)
Posted: 2020-07-03 04:36 AM . Last Modified: 2023-10-31 10:45 PM
