DCE server
  • DCE server
127
Posted: ‎2020-07-04 02:25 PM . Last Modified: ‎2024-04-05 02:38 AM
988
DCE server
Good day
Can you view the health of DCE Server via its client ?
Im only able to determine the hard disk size and utilization but the overal health i cannot get... any ideas?
(CID:128758779)
Replies 4
988
Hi Juice,
I know that product management is looking to add an enhancement of this type for the next generation product but I do not believe it is being actively looked at for DCE 7.x. There's currently no way to monitor much other than IPMI in the case of a hardware server or, if you're running a VM, you can monitor resource usage.
Steve
(CID:128758927)
Thank you to all that has responded, very much appreciated.
This is not exactly what i was hoping for. I thought that there was a "how to enable server health" option that we could get stats.
will do some more research and if i get new info will post.
Thanks again.
(CID:128759175)
Ways I can think of:
  1. Connect to StruxureOn, if it is available in your country, as you'll get notified when DCE lost comms to StruxureOn.
  2. From DCE web client, under Status option
  3. Monitor DCE physical server component status via SNMP. You can enable SNMP from DCE server access like below.
Some commonly used OIDs for linux, taken from:
https://www.centos.org/forums/viewtopic.php?t=49064
Network Interface Statistics
List NIC names: .1.3.6.1.2.1.2.2.1.2
Get Bytes IN: .1.3.6.1.2.1.2.2.1.10
Get Bytes IN for NIC 4: .1.3.6.1.2.1.2.2.1.10.4
Get Bytes OUT: .1.3.6.1.2.1.2.2.1.16
Get Bytes OUT for NIC 4: .1.3.6.1.2.1.2.2.1.16.4
CPU Statistics
Load
1 minute Load: .1.3.6.1.4.1.2021.10.1.3.1
5 minute Load: .1.3.6.1.4.1.2021.10.1.3.2
15 minute Load: .1.3.6.1.4.1.2021.10.1.3.3
CPU times
percentage of user CPU time: .1.3.6.1.4.1.2021.11.9.0
raw user cpu time: .1.3.6.1.4.1.2021.11.50.0
percentages of system CPU time: .1.3.6.1.4.1.2021.11.10.0
raw system cpu time: .1.3.6.1.4.1.2021.11.52.0
percentages of idle CPU time: .1.3.6.1.4.1.2021.11.11.0
raw idle cpu time: .1.3.6.1.4.1.2021.11.53.0
raw nice cpu time: .1.3.6.1.4.1.2021.11.51.0
Memory Statistics
Total Swap Size: .1.3.6.1.4.1.2021.4.3.0
Available Swap Space: .1.3.6.1.4.1.2021.4.4.0
Total RAM in machine: .1.3.6.1.4.1.2021.4.5.0
Total RAM used: .1.3.6.1.4.1.2021.4.6.0
Total RAM Free: .1.3.6.1.4.1.2021.4.11.0
Total RAM Shared: .1.3.6.1.4.1.2021.4.13.0
Total RAM Buffered: .1.3.6.1.4.1.2021.4.14.0
Total Cached Memory: .1.3.6.1.4.1.2021.4.15.0
Disk Statistics
Add the following line to snmpd.conf and restart:
includeAllDisks 10% for all partitions and disks
Disk OID's
Path where the disk is mounted: .1.3.6.1.4.1.2021.9.1.2.1
Path of the device for the partition: .1.3.6.1.4.1.2021.9.1.3.1
Total size of the disk/partion (kBytes): .1.3.6.1.4.1.2021.9.1.6.1
Available space on the disk: .1.3.6.1.4.1.2021.9.1.7.1
Used space on the disk: .1.3.6.1.4.1.2021.9.1.8.1
Percentage of space used on disk: .1.3.6.1.4.1.2021.9.1.9.1
Percentage of inodes used on disk: .1.3.6.1.4.1.2021.9.1.10.1
System Uptime: .1.3.6.1.2.1.1.3.0
(CID:128759076)
Posted: ‎2020-07-04 02:25 PM . Last Modified: ‎2023-10-22 01:27 AM
