DCE initial configuration
  • DCE initial configuration
127
65
Posted: ‎2020-07-05 02:37 PM . Last Modified: ‎2024-04-03 11:50 PM
1025
After i finished successfully with the configuration of the network settings, and have an access to the web of the DCE server, is there any initial configuration i should make?
I tried to get into the client and it showed me this message: "The credentials you have entered are invalid for this StruxureWare Data Center Expert server."
Thanks in advance.
(CID:137104573)
Posted: ‎2020-07-05 02:38 PM . Last Modified: ‎2024-04-03 11:50 PM
Dear sheep,
As I wrote in your previous topic , the initial login/password in the DCE-client and web-GUI is apc/apc.
Now i need to relate the login to the active directory for the team of the company.
Except that, the system is ready to work? There's no other operations to do?
This is correct, change the default password for the user apc and you can assume, that the initial configuration is complete.
With respect.
(CID:137104619)
Replies 4
Dear sheep,
With respect.
(CID:137104619)
Yes you are totally right, i've entered apc/apc and it worked. missed this information.
(CID:137104616)
Dear sheep,
See my answer below.
(CID:137104629)
Posted: ‎2020-07-05 02:38 PM . Last Modified: ‎2023-10-22 01:25 AM
