AD auth to external domain
  • AD auth to external domain
127
Posted: ‎2020-07-05 02:37 PM . Last Modified: ‎2024-04-03 11:50 PM
1250
Hello
We are trying to configure following situation.
We have domain A, where all users are registered. We have "tech "domain B, which is accessible for DCO and DCE and it has security groups configured which we want to allow to connect to the systems. There is a trust between A and B domains. We are able to connect with A domain users to the Windows based applications/services (IIS, RDP connections). But I'm unable to configure DCO and DCO for authentications using A domain users. Using B domain users is working OK.
Is such configuration possible at all?
(CID:137104510)
  • Data Center Operation
1250
Hi Olegas,
How about configuring separate/new authentication server settings for "Domain A" (similar configuration that you have done for Domain B, which works), then you will have two authentication servers configured in DCO, one for Domain B and one for Domain A.
Kind regards
(CID:137104953)
Replies 5
1251
Hi Olegas,
Kind regards
(CID:137104953)
Hello
Thank you for reply.
Thing is that our network team is quite restrictive and system is beeing put to the "shared" network and they don't want to allow direct connection to the domain A. That's why we are in such situation.
(CID:137104989)
Hi Olegas,
You are welcome - then unfortunately your special/complex configuration (as you've already tested) is unsupported in DCO.
Kind regards
(CID:137105917)
Thank you. Will search for other solution.
(CID:137106885)
Posted: ‎2020-07-05 02:37 PM . Last Modified: ‎2023-10-20 04:54 AM
