DCE failed backup - alarm configuration
Showing results forΒ
Did you mean:Β
  • DCE failed backup - alarm configuration
129
72
Posted: β€Ž2020-07-05 04:03 PM . Last Modified: β€Ž2024-04-03 11:12 PM
1280
Hello to all the professionals
Is there a way that we can get an active alarm (or any other alarm) for a failed DCE backup?
For example, when DCE backup fails at night, i want to get an alarm at this window in DCO :
just like we get alarms for temperature or humidity issues.
Thanks!
(CID:137732055)
  • Data Center Operation
Dear sheep,
Sorry, but this is not possible.
In short, the current DCE-7.x software sends email notifications about of failed backup only to DCE administrators (if the correct email addresses have been entered in System -> User and Device Group Access...).
This type of notification is not subject to any DCE notification policies. This, if you want, such a DCE-7.x appliances design πŸ˜€.
If you have more questions, please ask.
With respect.
(CID:137732112)
Replies 4
Dear sheep,
With respect.
(CID:137732112)
1280
Hi sheep
Whilst @spezialist is correct, there might be a way to achieve what you want but I suspect it will not be trivial.
I'm happy to discuss with you if you wish
Cheers
Ed
(CID:137732244)
Hi Ed,
Thanks, i'll be happy to hear about this option.
Can we talk in private maybe?
Sheep.
(CID:138807360)
Posted: β€Ž2020-07-05 04:03 PM . Last Modified: β€Ž2023-10-22 01:24 AM
