Posted: 2020-07-05 04:02 PM . Last Modified: 2024-04-03 11:13 PM
Hi
This template relevant when we want to do an import for equipment inside a rack, quick and easy way to do it.
So, if i want to do the opposite process - i mean, to take an exist rack with servers, make export and get this excel template.
Is it possible?
Thanks.
(CID:137732042)
Posted: 2020-07-05 04:02 PM . Last Modified: 2024-04-03 11:12 PM
You can export the list of equipment to a file via for example "Equipment Browser", more info available here:
Working with the Equipment Browser
Exporting Equipment Browser table
Kind regards
(CID:137732236)
Posted: 2020-07-05 04:03 PM . Last Modified: 2024-04-03 11:12 PM
i think you haven't understood me.
Hope that i'm not wrong - i want to make the exactly opposite process of import excel workbook.
The import process says that i bring an external and fully template and make an import for this inside an empty rack.
what I want to do, is to get this exactly template above from one existing rack; this is the opposite process actually from what i described above.
The guides you gave me are not what i mean.
Hope you understand me better now, if not i'll be happy to give you screenshots.
Thanks!
Sheep.
(CID:138807364)
Hi Sheep,
The reverse, eg. the exact opposite process of the equipment importer (via excel sheet) is not possible/supported.
Currently available options to export data from DCO may be, as mentioned via Equipment Browser and/or via ETL (External system integration through ETL)
Kind regards
(CID:138807541)
Posted: 2020-07-05 04:03 PM . Last Modified: 2023-10-22 02:04 AM
