DCE client application will only connect when “Use SSL to Connect”
  • EcoStruxure IT forum
  • DCE client application will only connect when “Use SSL to Connect”
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 11:03 PM . Last Modified: ‎2024-04-09 01:15 AM
899
I am facing a problem on  Windows 7 64 bit machine where the client application will only connect when “Use SSL to Connect” is checked or else we get the below error:
(CID:105462101)
  • Data Center Operation
Replies 6
Ali, Can you access the web page of Data Center Expert by going to its IP address in a web browser using http (port 80)? ~Cory
(CID:105462103)
899
Hi Ali,
I was wondering perhaps the server access via port 80 is disabled on the server itself.
It can be verified via DCE client,  System > Server Administration Settings > Server Access... :
Kind regards
(CID:105462131)
Hi Jef, It is enabled as we are connecting from other machines over http.
(CID:105462209)
Another option is that Firewall could be blocking connection on port 80.
(CID:105462183)
Hi, It is enabled as we are connecting from other machines over http.
(CID:105462206)
Posted: ‎2020-07-02 11:03 PM . Last Modified: ‎2023-10-31 10:25 PM
