Posted: 2021-04-10 07:21 AM
I am working on a DCE project that has Netbotz 750 but i am facing a problem to open the web page of Netbotz 750 from DCE as i have got the following error
taking into consideration that i have configured Netbotz 750as per manual and also I can open it's web page directly from browse and also I can see all sensors from DCE but only I get this error when I am trying to open the web page from DCE directly.
thanks
Posted: 2021-04-10 09:04 AM
Hi @eslamsabry2230 ,
im going to assume the NetBotz 750 is on the DCE private LAN. If so, this is a known issue currently being looked at as per:
https://www.apc.com/bm/en/faqs/FA411321/
thanks,
Steve.
thanks,
Steve.
Posted: 2021-04-10 09:10 AM
Thanks Steve.
your assumption is right as i am connecting it to the private network. so until that issue has been solved i will try to connect it to the public port.
thanks,
Posted: 2022-10-04 03:49 PM
It works ? Facing the same issue here since update 5.3.1.175...
Posted: 2023-02-01 09:25 AM
Please sir, did it worked when you connect to public port?
