Posted: 2020-07-02 10:15 AM . Last Modified: 2024-04-10 12:57 AM
Is it possible to install your own SSL certificate on the DCE Web dashboard?
--Christian
(CID:93914220)
Hi Christian,
It is possible to configure the Server Access to DCE using the DCE client menu System->Server Administration Settings->Server Access
It is possible to change http(s) port(s) and Modify Certificate... Using the modify certificate will allow to add a certificate to the DCE web server.
As also noted in the configuration window it might impact the Netbotz communication when changing ports.
(CID:93914282)
Hi Christian,
(CID:93914282)
Posted: 2020-07-02 10:15 AM . Last Modified: 2023-10-31 10:45 PM
