Posted: 2020-07-02 05:04 PM . Last Modified: 2024-04-09 02:35 AM
Hi Support Team,
I saw some information stating that the recommended virtual machine hardware specs for our DCE is 4GB of RAM and 4 CPU's to cater 4025 devices, I would like to verify if its the maximum hardware resources we can put in or still possible to increase the RAM to 8gb or 16gb?
please advise.
(CID:103586508)
Hi Eric,
You can add more ram if you want but this is the minimum recommended for the maximum number of nodes. If you want to monitor 4025, you need at least 4 gig. I would recommend 8 or more but again, this will not allow for more nodes being monitored.
Steve
(CID:104173579)
Hi Eric,
Steve
(CID:104173579)
Posted: 2020-07-02 05:04 PM . Last Modified: 2023-10-31 10:45 PM
