DCE Reports UPS Runtime
  • EcoStruxure IT forum
  • DCE Reports UPS Runtime
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 10:34 PM . Last Modified: ‎2024-04-03 12:25 AM
927
When creating a UPS Run-time report. The data populates a report with the IP Address, Hostname, Model, Run-time, Battery Replacement State. How would i add the location to the report?
(CID:149294022)
Posted: ‎2020-07-05 10:35 PM . Last Modified: ‎2024-04-03 12:25 AM
927
Figured this out: If you create a custom report.  Then choose devices or groups. then select sensor Battery Time Remaining. Then on the right of the search section you will see a excel spreadsheet icon, you can select the locations as custom property.
(CID:149294155)
928
(CID:149294155)
Excellent! Thanks for posting your solution 😀
(CID:149294263)
Posted: ‎2020-07-05 10:35 PM . Last Modified: ‎2023-10-22 01:19 AM
