DCE Failed to transmit Alert
  • EcoStruxure IT forum
  • DCE Failed to transmit Alert
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 04:33 PM . Last Modified: ‎2024-04-03 05:03 AM
448
Hi
I am having these error appear in DCE logs as follows
The destination IP was an old DCO connected to this DCE before it was decommissioned.
How can I remove these error from the logs?
Best Regards,
TJ
(CID:138810042)
  • Data Center Operation
448
Hi Tj,
there is no place in DCE to remove the posts to DCO. Likely this is causing no issue and if that’s the case should be ignored. If however you feel you must get rid of these, the only way I know to do it is to:
1: recreate the DCO server at the same IP address as before
2: add this DCE server as a remote server
3: verify DCO is receiving data
4: remove DCE as a remote server
5: get rid of your new DCO server.
Because DCO was simply shut down and the  the servers were never told to stop communicating in this way, DCE will keep reaching out.  I believe this will stop it.
Steve.
(CID:138810059)
Hi Steve,
Thanks for the reply.
I will try it out.
BR
TJ
(CID:138810068)
Posted: ‎2020-07-05 04:33 PM . Last Modified: ‎2023-10-22 01:16 AM
