Posted: 2020-07-05 06:25 PM . Last Modified: 2024-04-03 03:00 AM
We are deploying DCE 7.6 OVA in Vmware Esxi6.5 and getting error when we start the Server. I tried with ISO file and the same result. Kindly advise why this error is coming and if there is anything we did wrong while creating the DCE Server. please find below screen shots.
Shemil
(CID:141267517)
Hi shemilusman,
Exactly how did you deploy the OVA? Maybe you can go step by step? The ISO is not supported for a VM install so if you're getting the same message deploying the OVA as you are with the ISO, that leads me to believe that somehow the OVA deployment may have been done in a non-standard manner. The ISO is to only be used along with a USB DVD or thumb drive to install on a hardware server. I can tell you that ESXI 6.5 is supported and tested.
Steve
(CID:141267909)
P.S.
This may also be helpful:
http://www.apc.com/us/en/faqs/index?page=content&id=FA299551
(CID:141267912)
Dear shemilusman,
Tell us, please, did you solve your problem or not?
With respect.
(CID:141269175)
Yes it is solved and 7.6 ova was installed.
Regards
shemil
(CID:141270610)
Ok, very thanks for the good feedback :-).
(CID:141270745)
Posted: 2020-07-05 06:25 PM . Last Modified: 2023-10-22 01:16 AM
