Posted: 2020-07-05 03:53 PM . Last Modified: 2024-04-03 11:16 PM
Hi folks,
I wanna request a DCE DDF, but the web system reported an error(see the screenshots ). I tried to switch to other browsers, but unfortunately the error existed as before.
Does anybody know how to solve it?
(CID:137730496)
Hi Zhang Hao,
Is your browser IE? If yes, could you try with Chrome/Firefox?
Edit: I just saw you tried other browsers.
Post please the console errors by opening the console (Chrome, Firefox, IE),
Edit 2: Jef is right, I will work on updating the error messages.
(CID:137730509)
Hi Panagiotis,
Please refer to the screenshot
Best Regards!
(CID:137730815)
Thanks for screenshots, if you click on the Body in the right panel you will see that the error message is "device already exists" or similar.
(CID:137730876)
Ok, thanks for the good feedback.
(CID:137731741)
Hi Hao-Cole,
I guess it might be because the device (Envicool CyberMate DX) is already existing and registered as supported. Search for this device returns,
You might want to try using the "I WANT IT TOO" or "Request modification" options:
Kind regards
(CID:137730512)
Hi Jef ,
I tried to search for the keywords (Envicool, CyberMate DX, CyberMate) with your advice, but it was different from your capture and there were no DDF files matching.
Best Regards!
(CID:137730801)
Dear Jef Faridi and Panagiotis Karampis,
Zhang Hao is right: I also cannot find this cooling device on the Device Support resource:
and using global search in general:
Very thanks for the support.
(CID:137730867)
Posted: 2020-07-05 03:54 PM . Last Modified: 2024-04-03 11:16 PM
The device is internal, it won't appear in the searches. Jef has admin rights thus can see it.
(CID:137730883)
Hello again,
spezialist and Zhang Hao
Jef is right. The device exists but is for internal use only. This is the reason it doesn't appear in your searches.
Zhang Hao, I am taking this directly to the DDF team.
(CID:137730881)
(CID:137730924)
@Panagiotis Karampis, the Envicool CyberMate DX ddf is still invisible at this moment.
(CID:137731750)
Hi Zhang Hao,
I found the DDF for this device under our "custom" directory. I don't believe those are accessible for download and may be the reason you see the "device already exists" error. It exists, but can't be downloaded. I have attached the DDF here for your convenience. If there are any issues with the DDF please let me know.
(CID:137731922)
Hi Nick
(CID:137731968)
Hi @Nicholas St Pierre,
The requested register map is totally different one and the data type is also greatly changed this time. Because a different type gateway is applied in the link. How can I request a modified DDF? Thanks in advance!
(CID:137732691)
Posted: 2020-07-05 03:54 PM . Last Modified: 2023-10-22 01:15 AM
