DCE-Apply Firmware Update device show problem
  • EcoStruxure IT forum
  • DCE-Apply Firmware Update device show problem
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 04:40 PM . Last Modified: ‎2024-04-03 04:25 AM
7
1938
Hello
In all customers where that installed DCE version 7.5 I have the same problem when I opened "Apply Firmware Updates" window.
No any devices areappears into windows where I need ro "Select Device Updates"
How I can fix it ?
(CID:138811493)
1938
Dear Boris,
This means, that either the DCE-server does not have firmware updates for your devices, or your devices has the latest firmware.
A DCE-server (not a DCE-client) can obtain firmware updates for your devices in two ways.
  • The first way is to import the DCE device firmware catalog (if the DCE-server does not have access to the Internet).
  • The second way is for the DCE-server to download the necessary firmware updates from online resource https://updates.apc.com/ (i.e. the DCE-server must have network access to the Internet at https://updates.apc.com:443).
If you have further questions, please ask.
With respect.
(CID:138811512)
Replies 7
1939
Dear Boris,
With respect.
(CID:138811512)
Posted: ‎2020-07-05 04:41 PM . Last Modified: ‎2024-04-03 04:25 AM
Hello
Many thanks for ypur answer I'll check .
Unfortunately the link of the download frimware is broken
(CID:138811546)
Boris,
You can see in your URL that you are trying to directly access https://updates.apc.com via a web browser, which is not possible.  You need to use the full link.  To access and download the upgrades manually, it would be: https://download.schneider-electric.com/files?p_Archive_Name=DBUE-7H7NVA.zip&p_enDocType=Software+-+...
If you are unable to access that full link, most likely something on your network is changing the URL, such as a proxy, and preventing the access/download of the file.  I have just tested the URL and the download works fine.
Kind Regards,
Cory
(CID:138811550)
many thanks
I haven't problem with full link . My question how I get this full link ?
(CID:138811565)
Posted: ‎2020-07-05 04:41 PM . Last Modified: ‎2024-04-03 04:24 AM
Video: How do I manually load APC and NetBotz device firmware to StruxureWare Data Center Expert?
https://www.apc.com/us/en/faqs/FA226042/
(CID:138811573)
Dear Boris,
Tell us, please, did you solve your problem or not?
With respect.
(CID:139693913)
Posted: ‎2020-07-05 04:41 PM . Last Modified: ‎2023-10-22 01:14 AM
