DCE API - sensorID for all sensors
  • DCE API - sensorID for all sensors
129
72
Posted: ‎2020-07-04 12:54 AM . Last Modified: ‎2024-04-05 04:20 AM
1827
Hi Team,
Asking on behalf of Jimmy Leung
Please kindly advise how to find the DCE sensorID for every DCE sensor.
Client is using this to built the API queries.
(CID:126166023)
Posted: ‎2020-07-04 12:55 AM . Last Modified: ‎2024-04-05 04:20 AM
Suggest to use ISXCentralDeviceService_v2_0 instead of v1.
See below example on DCE 7.4.3 using SOAP UI for getAllDevices request:
(CID:126168138)
Replies 10
1826
HI Lukasz and Jimmy Leung
The SensorService provides a range of calls and perhaps most simply, use the getSensorsForDevice by providing the Device ID which can be obtained by using the getAllDevices call in the DeviceService.
Say Hi to Jimmy.  Let me know if you need a hand
Cheers
Ed
(CID:126166364)
Hi Ed,
I tried the getAllDevices call in the DeviceService in our DCE (7.4.3) but I am getting this response:
http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            soap:Client
            Could not find appropriate operation for request getAllDevices() in service 'ISXCentralDeviceService_v1_0'
Can you spot anything wrong?
Regards
(CID:126166396)
Hi Ed,
Thanks for helping out.
Can you kindly look at Jimmy's comments and see if you can spot something wrong?
Anyone else would like to comment please feel free to chip in...
(CID:126168046)
Thanks Chris,
Good pick-up with the version.
Jimmy Leung,
Please letus know if this helps.
(CID:126168087)
Chris,
Thanks for your response, Unfortunately I don't have ISXCentralDeviceService_v2_0 documentation. I only can try using V1 format which I expected to return with error. Can You please share with me the correct format for the Xmls:isx2 query format or share with me the link for the full documentation.
(CID:126168098)
Hi Jimmy,
Its available from the DCE itself, use:
http:///integration/services/?wsdl
Replace with your DCE's ip address.
Fore more detail explanation on the usage of the call:
StruxureWare Data Center Expert Web Services API
Chris
(CID:126168103)
(CID:126168138)
Thanks Chris/Ed/Lukasz.
Got it working now, Thanks.
For me, it is just the beginning!
Cheers
(CID:126169301)
No problem,glad to be of assistance.
(CID:126169303)
Posted: ‎2020-07-04 12:55 AM . Last Modified: ‎2023-10-22 01:14 AM
