Posted: 2020-07-05 05:31 PM . Last Modified: 2024-04-03 03:20 AM
Good Day,
I am trying to generate reports from DCE for my ACRD600 but I am not getting any sensors to select from it is only giving the link status and a device status option, can the ACRD600 give more sensor values to use or is it something with DCE?
(CID:140708894)
Hi Terrance,
is it just the reporting feature showing no values for the device or if you right click the device and choose “view sensors” do you also see a limited number of sensors?
What version of DCE do you have? Have you updated the DDFs on the system lately? If no sensors are showing anywhere, it is likely missing a DDF.
Steve
(CID:140708943)
Hi Terrance,
Steve
(CID:140708943)
Posted: 2020-07-05 05:32 PM . Last Modified: 2024-04-03 03:20 AM
If i right click and choose "view sensors" the same limited sensors show up.
the server is running 7.4.1, no i haven't updated the DDFs recently. its an APC unit, shouldn't it have the latest DDFs?
(CID:140708950)
Hi Terrance, as spezialist mentions, it is likely the lack of the proper DDF.
Steve
(CID:140709410)
adding the DDF file worked, thanks
(CID:140710408)
Posted: 2020-07-05 05:32 PM . Last Modified: 2024-04-03 03:19 AM
Ok, thanks for the good feedback 😀.
(CID:140710522)
Dear terrence ramnarine,
First you need to check from DCE-client which version of the SNMP DDF-file Schneider ACRD2G is installed?
For example, from the DDF resource you can now download the SNMP DDF-file apc_acrd2g.xml v.12:
Perhaps - this will be the solution to your problem.
Try and report the result, please.
With respect.
(CID:140710519)
Good day,
Adding the DDF file worked, thanks
(CID:140710411)
Posted: 2020-07-05 05:32 PM . Last Modified: 2023-10-22 01:13 AM
