Posted: ‎2020-07-05 04:54 PM . Last Modified: ‎2024-04-03 04:20 AM
Hello
When starting DCE desktop client I'm getting an error that version is invalid. However I'm using the client, that is downloaded from the DCE web portal.
I've tried reinstalling client, but without any luck
(CID:139692874)
Figured out. Issue was with timeout to OLD LDAP server, where my current user had same login name.
In logs found exceptions
(CID:139692917)
If I select Yes on prompt it opens the pag ewith URL http://127.0.0.1:0/
(CID:140217472)
(CID:139692917)
Posted: ‎2020-07-05 04:54 PM . Last Modified: ‎2023-10-22 01:13 AM
