DCE 7.6 Upgrade - AD authentication fails
  • EcoStruxure IT forum
  • DCE 7.6 Upgrade - AD authentication fails
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 12:48 PM . Last Modified: ‎2024-04-04 12:45 AM
691
After migrating DCE 7.5 to DCE 7.6 AD authentication fails using SSL.  SSL cert, credentials and settings have not changed.  I am able to connect to AD without SSL using the unsecured port but this is not an acceptable solution.  please advise.
(CID:134683254)
I assume you may have already found the solution, but if not as a work around, you can use the hostname of your AD server instead and still use SSL
I found this post on another applications support site that helped
https://support.mulesoft.com/s/article/Error-No-subject-alternative-names-matching-IP-address-when-u...
(CID:135433550)
Posted: ‎2020-07-05 12:48 PM . Last Modified: ‎2023-10-22 01:13 AM
This is a heading
