Posted: 2020-07-03 04:24 PM . Last Modified: 2024-04-08 12:39 AM
Hi All,
Need help! I could not get connect or very unstable to DCE 7.4.3 client Linux ?
it worked perfectly for early version DCE7.2.1
Minh
(CID:119050402)
Posted: 2020-07-03 04:24 PM . Last Modified: 2024-04-08 12:38 AM
Hi Minh Pham,
I successfully use the DCE-7.4.3 client on CentOS-7.3. Above mentioned problems I did not notice. It seems to me that you have not the problem DCE-client...
What Linux distribution do you use?
With respect.
(CID:120134403)
It works perfectly in Ubuntu 14.04, the most reliable Ubuntu so far.
Minh
(CID:119050428)
Hi Minh Pham,
With respect.
(CID:120134403)
Hi Minh Pham,
Tell me, please, have you solved the problem or not?
With respect.
(CID:120134414)
Posted: 2020-07-03 04:25 PM . Last Modified: 2024-04-08 12:38 AM
Hi Spezialist,
Thanks for your respond, i was able to run the DCE Linux client on Ubuntu 16.04.
Minh
(CID:120134408)
Posted: 2020-07-03 04:25 PM . Last Modified: 2023-10-22 01:11 AM
