DCE 7.3.1. Backup Issue
  • EcoStruxure IT forum
  • DCE 7.3.1. Backup Issue
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 07:09 AM . Last Modified: ‎2024-04-08 04:17 AM
777
Hi Team!
We have a Customer with backup issue on DCE 7.3.1.
Backup is configured to backup data to windows share. Share is mounted successfully and DCE can start backup process, but fails in a while. Configuration backup is complete successfully, but Full backup always fails.
Here is a part of nbc log:
12.10.16 11:05:23.530 INFO - Mount Success: Able to write to the remote mount point 12.10.16 11:21:31.887 WARN - Failed to backup the local repository. Remounting the remote share and retrying. ERROR: Failed to backup the local repository to /data/mount/backup/ISX_new/synchronized_isx-2_20161012110523_7.3.1 10-12-2016 11:21:31 (com.netbotz.server.services.backup.impl.BackupJob) 12.10.16 11:34:33.693 ERRR - backup failed (com.netbotz.server.services.backup.impl.BackupJob) 12.10.16 11:34:33.707 ERRR - Backup Log: LOG: Backup started 04-05-2016 09:52:09 (com.netbotz.server.services.backup.impl.BackupJob)
and nbcBackup log:
LOG: Backup started 10-12-2016 11:05:23 LOG: Synchronized backup 10-12-2016 11:05:23 LOG: Wrote /data/mount/backup/ISX_new/synchronized_isx-2_20161012110523_7.3.1/backup.properties with values: Synchronized 7.3.1 isx-2 false 10-12-2016 11:05:25 LOG: Local ddfs sync started 10-12-2016 11:05:25 LOG: Local ddfs sync finished 10-12-2016 11:05:27 LOG: Server configuration backup started 10-12-2016 11:05:27 LOG: Backup up database netbotz 10-12-2016 11:05:28 LOG: Backup up database thresholding 10-12-2016 11:05:28 LOG: Creating tar archive 10-12-2016 11:05:28 tar: /etc/nbc/SensorContexts: Warning: Cannot stat: No such file or directory tar: /data/web/companylogo: Warning: Cannot stat: No such file or directory LOG: Server configuration backup finished 10-12-2016 11:05:31 LOG: Configuration backup complete 10-12-2016 11:05:31 LOG: Local repository sync started 10-12-2016 11:05:31 rsync: read errors mapping "/data/local/sensor2/Bd294d1/Bd294d1_nbSNMPEnc515B4F11/2016/enclosure.db": Input/output error (5) WARNING: sensor2/Bd294d1/Bd294d1_nbSNMPEnc515B4F11/2016/enclosure.db failed verification -- update discarded (will try again). rsync: read errors mapping "/data/local/sensor2/Bd294d1/Bd294d1_nbSNMPEnc515B4F11/2016/enclosure.db": Input/output error (5) ERROR: sensor2/Bd294d1/Bd294d1_nbSNMPEnc515B4F11/2016/enclosure.db failed verification -- update discarded. rsync: stat "/data/mount/backup/ISX_new/synchronized_isx-2_20161012110523_7.3.1/data/local/sensor2/Bd294d1/Bd294d1_nbSNMPEncA9A10301/2016/.sensor.035.FV5iAw" failed: Read-only file system (30) rsync: rename "/data/mount/backup/ISX_new/synchronized_isx-2_20161012110523_7.3.1/data/local/sensor2/Bd294d1/Bd294d1_nbSNMPEncA9A10301/2016/.sensor.035.FV5iAw" -> "sensor2/Bd294d1/Bd294d1_nbSNMPEncA9A10301/2016/sensor.035": Read-only file system (30) rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1039) [sender=3.0.6] ERROR: Failed to sync the local repository 10-12-2016 11:21:31 LOG: Failed to backup the local repository to /data/mount/backup/ISX_new/synchronized_isx-2_20161012110523_7.3.1 10-12-2016 11:21:31
It seems like "/data/local/sensor2/Bd294d1/Bd294d1_nbSNMPEnc515B4F11/2016/enclosure.db" file is corrupted.
Could you advice how we can fix this issue?
(CID:108828997)
778
Take a look at this thread that was posted a few days ago as it might help:
(CID:108829050)
Posted: ‎2020-07-03 07:10 AM . Last Modified: ‎2024-04-08 04:17 AM
Thank you Michael, but it's not the case.
(CID:108829103)
Posted: ‎2020-07-03 07:10 AM . Last Modified: ‎2023-10-22 01:09 AM
