Posted: 2020-07-02 01:43 PM . Last Modified: 2024-04-09 04:27 AM
I am facing a lost communication problem with DCE after every 30 to 40 second, error message is "the client has lost communication with the server"
I have upgrade the server from 6.0.2 to 7.2.2 but problem is still.
BR,
Rana Ajmal
(CID:99156071)
I just want to tell you that after troubleshooting I got the solution, this problem was occurred due to antivirus, I just add the DCE client exe into trusted item and run the client the following problem has been resolved.
BR,
Rana
(CID:105457262)
Dear Rana,
I do not think that this issue is related to DCE 7.2.2 version as I am using the same version and I do not face this issue.
Here are some of the tips that I would like you to check:
regards,
Bala
(CID:99156098)
I have posted one more question regarding this issue in the post from 2014. If you have any advises or solutions please post it here. Thanks! http://dcimsupport.apc.com/questions/89555492/answers/102924678?flashId=1849116183
(CID:102924680)
Hi, I just want to tell you that after troubleshooting I got the solution, this problem was occurred due to antivirus, I just add the DCE client exe into trusted item and run the client the following problem has been resolved. BR, Rana
(CID:105457261)
BR,
Rana
(CID:105457262)
Posted: 2020-07-02 01:43 PM . Last Modified: 2023-10-31 10:24 PM
