Posted: 2020-07-02 12:52 PM . Last Modified: 2024-04-09 11:41 PM
I am facing a problem in DCE 7.2.2, I just set the time and date after that server was automatically restarted, after that I was tried many time through DCE Client and web browser but no response from server, IP ping status is ok. please help.
BR,
Ali
(CID:96765423)
Hi Ali,
Just setting the time alone should have no impact on the server's accessibility. Something else was either changed or was corrupted prior to the reboot. I would suggest physically rebooting the server and, if it is a hardware server, verifying there are no hardware errors reported on the server's screen.
Assuming no hardware errors, I would try accessing the server via both http and https in case one was turned off. Additionally, if it is a hardware server, I suggest connecting to the private LAN. If you still can not access it, it may be best to speak directly with support as this could take some time and posting back and forth will only increase that time.
Finally, if it is the time that you're setting, it sounds like you may be still in the initial setup phase,If that is the case, it may simply be quicker to re-image the system, rediscover the devices, and recreate the reports. All this of course assuming you have no backup to import.
Steve
(CID:97484815)
Posted: 2020-07-02 12:53 PM . Last Modified: 2024-04-09 11:41 PM
Hi Stave, after restore the image file now its working..
(CID:97484971)
Glad you got it resolved Ali!
(CID:97484999)
Posted: 2020-07-02 12:53 PM . Last Modified: 2023-10-31 10:24 PM
