DCE 7.2.1 restore issue
  • EcoStruxure IT forum
  • DCE 7.2.1 restore issue
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 09:50 PM . Last Modified: ‎2024-04-09 01:39 AM
756
Team,
A customer tried to update a DCE server from 7.2.1 to 7.2.2. After the update the server was hanging and it was not possible to login with the client.
Fortunately we had a backup so we decided to restore the 7.2.1 server. We were able to do this without any issues, but  after applying the backup to the fresh 7.2.1 it also hangs – please see attached images.
Any ideas on how we can trouble shoot this further?
Christian
(CID:105459394)
Replies 10
Hello Christian, Prior to trying the upgrade or the restore did you run an MD5 Checksum on the downloaded files. Generally speaking issues like you're having steam from a corrupted download. Thanks Victor
(CID:105459404)
756
Hi Christian,
please check if you have enough space on the DCE hard-disk. I saw this kind of issues when hard-disk was almost full.
Regards
Michael
(CID:105459419)
Good idea! Will check disk space. Thanks 🙂
(CID:105459429)
Hi Victor, we did not do a MD5 checksum (thanks for the reminder! 😉 but the restore itself went fine, we could log in to the client and discover devices, etc. It only hangs when we try to restore the backup file into the server.
(CID:105459428)
756
Hi Christian,
Check the completion of the restore files, see if it shows complete = true from backup.properties file per below.
Also worth trying, try restoring it on a DCE 721 VM (do add the VM's hdd if your data is huge) to verify....
Chris
(CID:105459640)
Posted: ‎2020-07-02 09:50 PM . Last Modified: ‎2024-04-09 01:38 AM
Hi Chris, The backup.properties does say complete = true but maybe the type has something to do with the issue? It is set to type = Configuration ? Christian
(CID:105459653)
Posted: ‎2020-07-02 09:51 PM . Last Modified: ‎2024-04-09 01:38 AM
Hi Christian,that means what you have is a config backup,not a full dc backup...:/
(CID:105459662)
But do you need a full backup in order to restore a solution?
(CID:105459896)
You can useDCE config backup to restore DCE config backup = DCE settings with no device data nor alarm history
(CID:105459897)
Posted: ‎2020-07-02 09:51 PM . Last Modified: ‎2023-10-31 10:24 PM
This is a heading
