Posted: 2020-07-05 03:19 PM . Last Modified: 2024-04-03 11:28 PM
Hello
We have some cooling issues as you can see in the picture below (the red row).
We don't find out what is the problem, we have configured other rows the same.
If someone has an ideas, i'll be happy to hear.
Thanks.
(CID:137111107)
That seems to be related to the orientation of the equipment/racks, apparently as notification is saying hot air is blowing into the cold aisle.
Kind regards
(CID:137111202)
Yes we checked the orientation and it all seems well.. we've made a comparison between other rows and it looks exactly the same. So probably the orientation isn't the problem.
About the notification - i forgot to say that we have already checked this subject and it seems that there is no hot air is blowing there. Is there any other option for this notification? It is shown on all the racks of the red row..
(CID:137111237)
Additional to the orientation of the racks, equipment location, distance between the equipment/racks and or distance to the wall may play a role.
Kind regards
(CID:137111808)
A little late answer but after we checked we don't find the problem - we've checked the orientation, the distances and other things you told me to check.
I add another perspective to this situation. In your opinion - is there any other potential problems for this red row issue?
Thanks!
(CID:137732049)
(CID:138807543)
Hi Sheep,
It is not clear from screen capture what might be the issue - location of the equipment (compared to each other), distance between the equipment (ex. between racks and walls, between cooling units, etc.) and even shape of the room may have contributing factor in simulations.
Kind regards
(CID:138807549)
Posted: 2020-07-05 03:19 PM . Last Modified: 2023-10-20 05:10 AM
