Posted: 2020-07-03 02:32 PM . Last Modified: 2024-04-08 01:17 AM
Hi
I configure the PUE values in DCO client as shown in picture.
I am getting the following PUE value in DCO web client.
When I am trying to configure the PUE in Portal server. I am getting the following error.
Any idea what I am doing wrong/missing?
Regards
Imran
(CID:116361022)
Hi Imran,
The portlet "Power Usage Effectiveness" is designed to display the PUE from Energy Efficiency setup.
For details about this add-on module please see the following page: StruxureWare Data Center Operation: Energy Efficiency
The PUE you have configured is the so-called simple PUE, and as far as I know, we do not have a supported portlet for that.
Kind regards
(CID:116361677)
Hi Jef
I could not find any option in DCO 8 to create or configure Energy system. Can you kindly explain what options I should click to find it.
Best regards
Imran
(CID:116362086)
Hi Imran,
StruxureWare Data Center Operation: Energy Efficiency is an add-on module, that can be enabled by installing the required license, namely Energy Efficiency license.
A short description of energy system setup is available here:
I would also suggest watching this video tutorial, presenting very nicely an energy efficiency configuration:
How to measure the data center energy efficiency
Kind regards
(CID:116362095)
Posted: 2020-07-03 02:32 PM . Last Modified: 2024-04-08 01:16 AM
Thanks Jef
I will check with Schneider sales person for Energy Efficiency Module License.
(CID:116362207)
You are most welcome, Imran
Kind regards
(CID:116362210)
Posted: 2020-07-03 02:32 PM . Last Modified: 2023-10-20 05:09 AM
