some modbus slaves are lossing connection periodically
Showing results forΒ
Did you mean:Β
  • some modbus slaves are lossing connection periodically
127
65
Posted: β€Ž2020-07-03 02:32 PM . Last Modified: β€Ž2024-04-08 01:16 AM
748
I'm monitoring a Circutor modbus devices. There are 27 slaves with the same modbus IP address and periodically some slaves are lossing connection.
(CID:116361027)
Posted: β€Ž2020-07-03 02:33 PM . Last Modified: β€Ž2024-04-08 01:16 AM
Hi Enric Climent,
Yesterday officially released the new DCE-7.4.3: StruxureWare Data Center Expert v7.4.3 Release Notes. And as it is written in the release:
Improvements to Modbus polling
Modbus polling is no longer affected by prolonged network disruptions.
Therefore, this may be another recommendation in the form of item number 5. Try it.
With best regards.
P.S.: In addition, here more detailed information from Jackie Lehr on this news subject on my question:
Q: Explain, please, in more detail, what do you mean? How is this achieved?
A: There was an issue where Modbus polling consumed resources if network connectivity was interrupted for an extended period. It is now fixed.
(CID:116920091)
Hi Enric Climent,
Unfortunately, at such number of Modbus slave devices it is normal πŸ˜€. I often meet similar problems. There are my recommendations:
  1. reduce number of Modbus slave devices on one IP address (to 5-8);
  2. reduce the frequency poll of Modbus slave devices (one poll in 2-3 minutes);
  3. increase the number of attempts of poll for each of problem Modbus slave devices (not 3, and 5-6 attempts – for DCE-7.3.1 and newer);
  4. increase timeout between unsuccessful attempts poll of Modbus slave devices (for example, up to 15 seconds – for DCE-7.3.1 and newer).
As option it is possible to reduce number of sensors, which are read out on Modbus slave devices.
And at last, to try to understand, and probably to reveal and eliminate defects of the Modbus serial communication line between Modbus devices. Practically, the last recommendation can be the most effective and useful.
With best regards.
(CID:116361050)
Hi Enric Climent,
With best regards.
(CID:116920091)
Posted: β€Ž2020-07-03 02:33 PM . Last Modified: β€Ž2023-10-22 09:36 PM
