Combine DCO 8.0.3 Servers for DR
  • EcoStruxure IT forum
  • Combine DCO 8.0.3 Servers for DR
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 12:42 PM . Last Modified: ‎2024-04-08 01:51 AM
768
I have a customer who would like to combine two Data Center 8.0.3 servers into a single entity. The customer would then like to create a DR Cluster or Node for the combined server.
My questions are:
  1. Is it possible to combine two  DCO 8.0.3 servers into a single entity.
  2. When creating the cluster will we have one DCO 8.0.3 server configured and installed as a "standalone" installation and then the other DR 8.0.3 servers installed as "cluster", or do we need to do two new installations using the "cluster" option during installation.
The reason I ask is that I was hoping to use the configuration listed below to accomplish what the customer is asking. I noticed this option stated we would have a "standalone" node and then the DR node. Basically, I am asking if I can leave the stand alone server alone, stand up a DR node using the cluster option, and then just configure the webmin setting and Virtual IP to get this done.
  • 1 standalone node + 1 DR node (requires 1 high availability license)
Thanks in advance for any reply.
(CID:110795642)
  • Data Center Operation
Replies 6
768
Hi Brian,
By combining the two data center servers, I assume we are talking about combining two different solutions running on two different DCO servers. Then yes, that is possible - we can use the migration feature in DCO to migrate a solution (backup file) from another setup. In DCO client, System Setup > Migrate from StruxtureWare Operation :
Let's imagine we have/had a "setup1" running on this server, and then we have used the migration feature to migrate the latest backup file from "setup2".  (standalone node)
Now we can attach this "standalone node" to a DR node.
(DR node basically installed as standalone).
So, I guess that could be the final setup, namely:
1 standalone server (operational DCO) + 1 DR node (requires 1 high availability license)
Kind regards
(CID:110795969)
Hi Jef, How many HA availability licenses required in the following requirement?
2 Cluster node
1 DR
does 1 qty of DCO HA license sufficient for the above requirement or does the Customer need to purchase three qty of DCO HA license(1 for DR & 2 for 2 qty of cluster nodes)?
(CID:111413208)
Hi Bala,
In the above example a cluster setup with DR, we would need two High Availability licenses (1 for the cluster itself, and 1 for the DR node).
Kind regards
(CID:111413316)
Thanks Jef!
(CID:111413351)
You are most welcome Bala,
Kind regards
(CID:111413354)
Posted: ‎2020-07-03 12:42 PM . Last Modified: ‎2023-10-20 05:09 AM
