Change power unit on DDF of powermeter
  • Change power unit on DDF of powermeter
126
65
Posted: ‎2020-07-05 11:45 PM . Last Modified: ‎2024-04-02 11:48 PM
1029
I have many ABB M2M powermeter. But on DCE it display apparent power as VA, I want to change this into to kVA on DDF file but it not working, empty unit on DCE. The same as other power as kW or kVAR. Although this code working fine on other powermeter as Siemens Pac3100
Please fix for me
(CID:152078109)
  • DDF
Dear Tinh,
Please raise a DDF modification request https://ddf.ecostruxureit.com/
One of our DDF members will respond to your modification request.
I suggest not to make any changes to the existing DDF manually by yourself as it can cause performance issues in DCE.
Bala
(CID:152078116)
Dear Tinh,
Bala
(CID:152078116)
Thanks for supporting. I resolved the issue
(CID:152078185)
Posted: ‎2020-07-05 11:45 PM . Last Modified: ‎2023-10-20 05:08 AM
