Change power unit on DDF of powermeter
EcoStruxure IT Forum
  • Re: Change power unit on DDF of powermeter
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 11:45 PM . Last Modified: ‎2024-04-02 11:48 PM
1367
I have many ABB M2M powermeter. But on DCE it display apparent power as VA, I want to change this into to kVA on DDF file but it not working, empty unit on DCE. The same as other power as kW or kVAR. Although this code working fine on other powermeter as Siemens Pac3100
Please fix for me
(CID:152078109)
  • Data Center Expert
  • DDF
DCIM_Support
DCIM_Support Mentor
Mentor
Dear Tinh,
Please raise a DDF modification request https://ddf.ecostruxureit.com/
One of our DDF members will respond to your modification request.
I suggest not to make any changes to the existing DDF manually by yourself as it can cause performance issues in DCE.
Bala
(CID:152078116)
Replies 3
DCIM_Support
DCIM_Support Mentor
Mentor
Dear Tinh,
Bala
(CID:152078116)
DCIM_Support
DCIM_Support Mentor
Mentor
Thanks for supporting. I resolved the issue
(CID:152078185)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 11:45 PM . Last Modified: ‎2023-10-20 05:08 AM
