Cannot connect to ETL database from Pentaho
  • Cannot connect to ETL database from Pentaho
129
72
Posted: ‎2020-07-02 02:42 PM . Last Modified: ‎2024-04-09 04:07 AM
7194
I've created an import ETL database, it's running but I cannot connect from Spoon database connection wizard. When I try the connection, I get the following error:
Error connecting to database [etl connection] : org.pentaho.di.core.exception.KettleDatabaseException:
Error occured while trying to connect to the database
Error connecting to database: (using class org.postgresql.Driver)
Conexión rechazada. Verifique que el nombre del Host y el puerto sean correctos y que postmaster este aceptando conexiones TCP/IP.
at org.pentaho.di.core.database.Database.normalConnect(Database.java:366)
at org.pentaho.di.core.database.Database.connect(Database.java:315)
at org.pentaho.di.core.database.Database.connect(Database.java:277)
at org.pentaho.di.core.database.Database.connect(Database.java:267)
at org.pentaho.di.core.database.DatabaseFactory.getConnectionTestReport(DatabaseFactory.java:86)
at org.pentaho.di.core.database.DatabaseMeta.testConnection(DatabaseMeta.java:2464)
at org.pentaho.ui.database.event.DataHandler.testDatabaseConnection(DataHandler.java:533)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.pentaho.ui.xul.impl.AbstractXulDomContainer.invoke(AbstractXulDomContainer.java:329)
at org.pentaho.ui.xul.impl.AbstractXulComponent.invoke(AbstractXulComponent.java:139)
at org.pentaho.ui.xul.impl.AbstractXulComponent.invoke(AbstractXulComponent.java:123)
at org.pentaho.ui.xul.swt.tags.SwtButton.access$500(SwtButton.java:26)
at org.pentaho.ui.xul.swt.tags.SwtButton$4.widgetSelected(SwtButton.java:119)
at org.eclipse.swt.widgets.TypedListener.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Widget.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch(Unknown Source)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820)
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.pentaho.ui.xul.swt.tags.SwtDialog.show(SwtDialog.java:378)
at org.pentaho.ui.xul.swt.tags.SwtDialog.show(SwtDialog.java:304)
at org.pentaho.di.ui.core.database.dialog.XulDatabaseDialog.open(XulDatabaseDialog.java:115)
at org.pentaho.di.ui.core.database.dialog.DatabaseDialog.open(DatabaseDialog.java:62)
at org.pentaho.di.ui.trans.step.BaseStepDialog$4.widgetSelected(BaseStepDialog.java:657)
at org.pentaho.di.ui.trans.steps.synchronizeaftermerge.SynchronizeAfterMergeDialog.open(SynchronizeAfterMergeDialog.java:843)
at org.pentaho.di.ui.spoon.delegates.SpoonStepsDelegate.editStep(SpoonStepsDelegate.java:136)
at org.pentaho.di.ui.spoon.Spoon.editStep(Spoon.java:7835)
at org.pentaho.di.ui.spoon.trans.TransGraph.editStep(TransGraph.java:2749)
at org.pentaho.di.ui.spoon.trans.TransGraph.editStep(TransGraph.java:1998)
at org.pentaho.ui.xul.jface.tags.JfaceMenuitem.access$100(JfaceMenuitem.java:26)
at org.pentaho.ui.xul.jface.tags.JfaceMenuitem$1.run(JfaceMenuitem.java:85)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:545)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:402)
at org.pentaho.di.ui.spoon.Spoon.readAndDispatch(Spoon.java:1221)
at org.pentaho.di.ui.spoon.Spoon.waitForDispose(Spoon.java:7044)
at org.pentaho.di.ui.spoon.Spoon.start(Spoon.java:8304)
at org.pentaho.di.ui.spoon.Spoon.main(Spoon.java:580)
at org.pentaho.commons.launcher.Launcher.main(Launcher.java:134)
Caused by: org.pentaho.di.core.exception.KettleDatabaseException:
at org.pentaho.di.core.database.Database.connectUsingClass(Database.java:502)
at org.pentaho.di.core.database.Database.normalConnect(Database.java:350)
... 63 more
Caused by: org.postgresql.util.PSQLException: Conexión rechazada. Verifique que el nombre del Host y el puerto sean correctos y que postmaster este aceptando conexiones TCP/IP.
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:136)
at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:66)
at org.postgresql.jdbc2.AbstractJdbc2Connection.(AbstractJdbc2Connection.java:125)
at org.postgresql.jdbc3.AbstractJdbc3Connection.(AbstractJdbc3Connection.java:30)
at org.postgresql.jdbc3.Jdbc3Connection.(Jdbc3Connection.java:24)
at org.postgresql.Driver.makeConnection(Driver.java:393)
at org.postgresql.Driver.connect(Driver.java:267)
at java.sql.DriverManager.getConnection(Unknown Source)
at org.pentaho.di.core.database.Database.connectUsingClass(Database.java:482)
... 64 more
Caused by: java.net.ConnectException: Connection timed out: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.(Unknown Source)
at org.postgresql.core.PGStream.(PGStream.java:62)
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:76)
... 73 more
Hostname : 192.168.15.94
Port : 5432
Database name : staging_prova_import
(CID:99158046)
  • Data Center Operation
7187
Hi Enric
Based on your comment above, please consider that the mask /32 means (as far as I know) that you only allow the specific address 192.168.15.0. If you want allow all addresses that are something like 192.168.15.* please use the mask /24 instead - like this:  192.168.15.0/24.
 Also see here for a cheat sheet on subnet masks: http://www.aelius.com/njh/subnet_sheet.html
You cannot update this directly in the configuration, so you have to remove the configuration and database and create new ones.
I hope this helps.
Best,
Niels
(CID:99158093)
Replies 5
7187
Hi Enric, did you follow instructions here when creating your database? Make sure to configure the network connections in ETL import db, as explained:
http://dcimsupport.apc.com/display/public/DCIMDEVELOPER/Configuring+network+connections+in+the+ETL+i...
(CID:99158048)
Hi Ajay,
Yes, I've created the database with a mask = 192.168.15.0/32 and I cannot connect from any server of this mask. I've tried to do telnet 192.168.15.94 5432 from command window a cannot connect too
(CID:99158080)
7188
Hi Enric
I hope this helps.
Best,
Niels
(CID:99158093)
Hi Niels,
Changing the mask I've could connect to the staging database.
Thanks for your help.
Enric
(CID:99158145)
Posted: ‎2020-07-02 02:42 PM . Last Modified: ‎2023-10-31 10:18 PM
