Can we get overhead busways as part of the genomes for DCO?
  • EcoStruxure IT forum
  • Can we get overhead busways as part of the genomes for DCO?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 08:59 AM . Last Modified: ‎2024-04-10 01:21 AM
687
I am using long and short power panels to simulate busways right now.  Would love to be able to get a proper busway genome.
(CID:90899924)
  • Data Center Operation
Posted: ‎2020-07-02 09:00 AM . Last Modified: ‎2024-04-10 01:21 AM
687
Hi Toby,
At present we don't support the busway(s). We are aware of the missing support. The work around you have done is the current way of modelling the busway setup.
(CID:92078085)
Replies 5
688
Hi Toby,
(CID:92078085)
Is there a way to specify the height above the floor?  The busway modeled from power panels shows as sitting on the floor in the 3D view.  I'm guessing once the busway type is available in the Genome Library the elevation/height above the floor will be one of the physical properties.  Any updates since this was brought up in 2014?
(CID:129413606)
No Update that I am aware off.  Still have them represented as outlined above. Like you stated they show on the floor in 3d view.
Toby
(CID:130092942)
I have the same problem with busways in my data center room. It's a shame!
any suggestions?
(CID:99157819)
Posted: ‎2020-07-02 09:00 AM . Last Modified: ‎2023-10-31 10:19 PM
