Can we Run DCE Report for specific time range on a date
  • EcoStruxure IT forum
  • Can we Run DCE Report for specific time range on a date
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 04:23 PM . Last Modified: ‎2024-04-08 12:39 AM
596
Hi Any one can assist me to get the report pull from DCE for specific time range on a date for example i need as below
From 25/05/2017 13:00:42  to 25/05/2017 16:35:29
(CID:119049929)
Hi Shaik Mahboob Ali,
Unfortunately specify a range of reports with the time impossible. Therefore, you will receive only a report for the entire day 25/05/2017 (or for the last 24, 12, 6 or 1 hour).
With best regards.
(CID:119049937)
An alternative,is to use  Web services to pull those data from DCE.
If this is something you'd need periodically, might be worth it to customized a report server via web services.
Specific to the web services, look under ISXCentralSernsorService_v2_0:
Look for getSensorDataRange  using:
Specific ISXCElementID for device & sensor
Start and end date in YYYY-MM-DDThh:mm:ss+02:00
The +02:00 indicates the time zone (GMT +2 etc)
You can use SOAP UI to test such request.
Link to DCE Web services API:
StruxureWare Data Center Expert Web Services API
(CID:119049971)
Posted: ‎2020-07-03 04:23 PM . Last Modified: ‎2023-10-20 05:06 AM
