Posted: 2020-07-04 02:36 AM . Last Modified: 2024-04-05 03:46 AM
(CID:126182880)
Dear tdparker94,
Judging from the name of the above sensors, they are exclusively analog sensors.
0-5V Cable (15ft) - NBES0305 is a cable, that connects to the standard Sensor Port of a NetBotz device. With this cable, the NetBotz device is able to measure the analog voltage in the 0-5V range.
Builtin 4-20mA Sensor Ports in NetBotz devices or an optional 4-20mA Sensor Pod (NBPD0129) are ports for measuring analog currents in the 4-20mA range.
If you have any questions, please ask.
With respect.
(CID:126182913)
Dear tdparker94,
With respect.
(CID:126182913)
They are both analouge....
(CID:126183976)
Thanks you very much for clearing this up.
(CID:126182922)
Posted: 2020-07-04 02:36 AM . Last Modified: 2023-10-20 05:05 AM
