Can anyone recommend a liquid flow sensor that would fit a 3/4" BSP pipe that will talk to EcoStruxure or preferably a Netbotz Device?
  • Can anyone recommend a liquid flow sensor that would fit a 3/4" BSP pipe that will talk to EcoStruxure or preferably a Netbot...
126
65
Posted: ‎2020-07-04 01:55 AM . Last Modified: ‎2024-04-05 03:59 AM
1049
I am looking for a liquid flow sensor device that will fit into a 3/4" BSP pipe or similar. I will need the flow sensor to talk to a monitoring solution like EcoStruxure, or even better, talk directly to a Schnieder Netbotz Device (essentially a 0-5V sensor or 4-20 mA).
Can anyone offer any advice? I surely can't be the only person looking for a liquid flow sensor in the data centre community.
Thanks.
(CID:126177141)
  • Asset Advisor
  • NetBotz
  • Cooling Optimize
Hi tdparker94, thanks for posting. Let's hope you find your answer here.
Kind regards Ditte
(CID:126178268)
Have you looked at ifm.  You will likely need to use adapters for the 3/8 BSP.  I like their sensors with display and they can feed into botz 0-5V or 4-20 mA.  I have ua ifm pressure sensor connected to a botz to monitor pressure of a boiler.
Of course the flow meter will need to be compatible with liquid and sanitary type if used with potable water/fluid.
https://www.ifm.com/gb/en/category/040/040_030/040_030_010_040#!/S/BD/DM/1/D/0/F/0/T/24
I have no expertise, just have noodled with Botz for a while. Use them in my barn to remotely monitor many things. Most are connected to 0-5 Vdc or dry contacts.
Nanoman
(CID:137105134)
Posted: ‎2020-07-04 01:55 AM . Last Modified: ‎2023-10-20 05:05 AM
