Can I reduce /home and add that space to root file system? I have tried via cmd line and then the DCO desktop client shows that the server is not starting up.
  • EcoStruxure IT forum
  • Can I reduce /home and add that space to root file system? I have tried via cmd line and then the DCO desktop client shows t...
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 07:52 PM . Last Modified: ‎2024-04-03 02:30 AM
1013
I would like to decrease /home by 10G and add that space to root file system as root is filling up.  Eventually I am going to upgrade DCO and change from a cluster install to disaster recovery but was looking for a quick fix now.  I attempted the resize the file systems via command line and all looked good and servers rebooted.  However, when I try to bring up the DCO client it states that the DCO server is in the process of starting or is down.  Can this be done?
(CID:144867566)
  • Data Center Operation
I ended up just adding a new disk and extending it that way.  The application is actually up and running!  Thanks for your input.
Krista
(CID:144867867)
Replies 4
Hello Krista.
Were the filesystems on your redhat server provisioned with logical volume manager? and is your DCO server a virtual machine (i.e. VMware guest of some kind)? If yes, be easier to add a small harddisk to the guest and expand the root filesystem.
I do not think we offer a supported procedure for shrinking the /home filesystem although I do see a number of procedures for redhat when I search online. Most of the procedures I see require /home to be unmounted and since DCO has at least one user account which uses /home this means you'd have to take DCO offline.
Assuming you're using LVM, is adding a disk an option for you?
Regards
Greg Sterling
(CID:144867809)
Krista
(CID:144867867)
Posted: ‎2020-07-05 07:52 PM . Last Modified: ‎2024-04-03 01:25 AM
Very good, that is the best course of action and that can be completely dynamically.
Regards
Greg Sterling
(CID:144867866)
Posted: ‎2020-07-05 07:52 PM . Last Modified: ‎2023-10-20 05:04 AM
