Bypass Not in Range
  • Bypass Not in Range
129
72
Posted: ‎2020-07-05 04:46 PM . Last Modified: ‎2024-04-03 04:23 AM
3065
Bypass Not in Range
Smart-UPS SRT 5000 - SRT5KRMXLT - Bypass not in Range - UPS input voltage or frequency cannot support bypass.  Does this point to power issues or settings on the UPS?
(CID:138812652)
Replies 13
3062
Hi Todd,
This is usually in input voltage issue. By default, I believe this is a 208v unit and if you feed it 240v, you may get that error. There's an FAQ that might help you with that:
http://www.apc.com/us/en/faqs/index?page=content&id=FA156585
Also I wanted to let you know that this site is usually more geared towards StruxureWare and NetBotz. The forums at:
https://community.se.com/t5/APC-UPS-Critical-Power-Cooling/ct-p/critical-power-cooling-racks
Are usually better suited to finding UPS specific content.
Steve
(CID:138812655)
So do i just need to switch the input power to 240 instead of 208?
(CID:138812675)
I guess that depends on what the regular input voltage is that your feeding the UPS. If this is a constant error, I'd assume that yes, you'd want to switch it to 240. Then you have to consider the output. What is on the output side of the UPS, what voltage does it need? Would 240 be an issue on the output side?
As  Eric mentioned in his comment, if this is just a brief change in voltage and you do not get this message on a regular basis, I would think changing the voltage would not be the best option and potentially changing the voltage high/low settings based on what your UPS is seeing:
If you're getting spikes and get this message intermittently, maybe you change the upper or lower limits. If you are plugged into 240, perhaps yes, you'd want to change the rated output voltage to match the input.
Either way, it's based on both the input you have and the output your load requires.
Steve
(CID:138812682)
It's a constant reading around 248.
(CID:138812687)
(CID:138812689)
Posted: ‎2020-07-05 04:46 PM . Last Modified: ‎2024-04-03 04:22 AM
Todd,
Again, knowing your load’s voltage requirements dictates the answer.
Steve
(CID:138812694)
Bypass not in range is often a message that comes along with other messages - like UPS on battery
As stated, it could happen if you connected it to an inappropriate voltage, but in my experience it is more likely occurring for 1 of 2 reasons :
  1. A legitimate voltage spike or sag (power outage might follow either) -  the minimum voltage required to supply the rated voltage without the battery (ie: when in bypass) is not available
  2. Voltage sags, but not significant enough to be actual problems - system alarm is overly sensitive and thus sends nuisance alarms - this can be adjusted by making the alarm less sensitive, I've done it, but I can't provide instructions at this time (consider changing this only if absolutely necessary in my opinion)
(CID:138812671)
Posted: ‎2020-07-05 04:47 PM . Last Modified: ‎2024-04-03 04:22 AM
3063
Hi Todd,
Since the difference of input voltages and output voltages very high that is why you are having alarm bypass frequency out of range, if you can control the main input supply voltage by adding voltage stabilizer or by changing the transformer tapping this issue could be solved. as i can see the output voltage and input voltages  difference is 40V.
If your connected load allows you to change the output voltage from 207V to 230V you can resolve issue this way also by decreasing the voltages difference.
BR
Haleem Malik
(CID:139691657)
How can i determine whether the load allows to change to 230?
(CID:139691845)
Hi Todd,
it is very simple check your connected load technical specifications, normally all IT equipment voltage range is 200V to 240V
(CID:139691850)
My devices do support 240v.  I was able to switch the UPS over to 240v and all is well.  Thanks for all of the great information.
(CID:140217484)
Great and thanks for update'
(CID:140217482)
Posted: ‎2020-07-05 04:47 PM . Last Modified: ‎2023-10-20 05:03 AM
