Best solution to monitor all Temp/Hum/air flow per rack ?
  • Best solution to monitor all Temp/Hum/air flow per rack ?
129
72
Posted: ‎2020-07-05 11:07 PM . Last Modified: ‎2024-04-03 12:14 AM
775
Please I need to know the best solution to monitor temp/humidity/air flow per each rack ?
so far I am using Netbotz 250, with AP9335TH but I cannot find any airflow sensors
Note: I know about room sensor pod 155 but I cannot use it as it is not rack mounted.
(CID:151060923)
  • Data Center Operation
  • NetBotz
Hi Pierre,
Good day!
Airflow sensors are innate with Netbotz Room Monitors (355 and 455) and with the Sensor Pod 155 (NBPD0155). See page 2 of the Netbotz Appliance Specifications that can be found from the link below:
Netbotz Appliance Specifications Sheet
The recommended way of installing a room monitor or a sensor pod in a rack can be seen in their respective installation manuals that can be accessed from the links below:
Room Monitor 355 Installation Manual Page 9
Room Sensor Pod 155 Installation Manual Page 11
From the images in the manual, the pod and the appliance is suggested to be installed at the top of the rack.
I hope this answers your question.
Kind regards,
Justine Chester
(CID:151061253)
Posted: ‎2020-07-05 11:07 PM . Last Modified: ‎2023-10-20 05:03 AM
